maybe burned starter?
Old Mar 20, 2009 | 12:25 PM
91_GTA305's Avatar
Car: 1991 Trans Am
Engine: sb chevy's.
So yea, one day i decided to hook back up the battery in the car to do the every week crank and stupid me put the terminals on backwords. Yes i know, stupid mistake of me, but now i need help. I checked all fuses and even replaced them with new ones to see if this would help get the juice flowing in the ignition and still no power. I do remember when i put the terminals on backwords smoke did rise from beneath the passanger header. Could I have screwed up the starter?
Old Mar 20, 2009 | 12:29 PM
Guest
Guest
Posts: n/a
Re: maybe burned starter?
it could just be the fuseble link wire. but is possible u smoked the wire on the startor
Old Mar 20, 2009 | 01:13 PM
10secondhopeful's Avatar
Car: '84 Z28
check the wires around the starter, you'll know if its been shot to hell. you can get a starter trigger that you hook directly up to the starter and use the batteries power, bypassing any fuse links, try this and see if you starter cranks over, to see if you did or didn't fry/seize it.
Replace wires that are melted, if not, check for the fuse link.
and then slap yourself for putting them on backwards
Old Mar 20, 2009 | 08:49 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Starter won't be damaged by reverse hookup,but
alternator(and any electronics)can be -smoke was
probably from a fuse link or alternator wire.
Old Apr 4, 2009 | 11:14 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Just to let u know. You more than likely fried ur ecm. Or brain box. Trust me i did this before.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
