Strange factory wire
Old Mar 20, 2009 | 09:02 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Ok I have the Chiltons manual, the Haynes manual, and the 82 Dealership repair/service manual. And in none of these can I find this wire, it's one wire, on the pass side frame rail and when I found it, it had a posative battery terminal attached to it, any idea's? I would like to figure out what it is before I attempt to hook it up and possably open a can of worms. It is a factory wire as it has the factory black plastic connector.
Old Mar 20, 2009 | 11:51 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: Strange factory wire
follow the wire and see what it leads too..how big is the wire
Old Mar 21, 2009 | 12:05 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Was it under the plastic frame on the door jamb?? most likely a previous sound system power lead... start pulling!
Old Mar 29, 2009 | 09:52 PM
Engine: 350 4bbl
No it's under the hood attached to the pass side sub frame rain, roughly a 16 gage black wire with a single pin connector, I unplugged the connector and removed the section with the batt terminal, however I havent the foggiest where it goes I lose it in the factory wiring bundles
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
mx127
Aug 10, 2015 08:13 AM
