wiper issue help!!!
Old Mar 25, 2009 | 03:54 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
wiper issue help!!!
ok i just bought this 86 IROC and the wipers dont work at all... the car has tilt wheel, cruise control... and i dont know if it has delay or not... since obviously i cant run them... i do know the lever turns 3 clicks... if that helps..lol....how do i find out or test to see if its the wiper switch or the motor that has failed.... i am not sure as to the diagnostics... please help if you can
Old Mar 25, 2009 | 04:09 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: wiper issue help!!!
did you check the fuse?
Old Mar 26, 2009 | 12:29 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
yes the fuse is good... i applied a hot wire directly to the wiper motor to the grey wire i believe... and the motor clicked but that was it... what wire do i tap into to try and make the motor run manually...
Old Mar 26, 2009 | 03:26 PM
1Aauto's Avatar
Former Sponsor
Get a test light and turn the wiper motor on by the switch.If the wiper motor has power to it that it has to be the motor. If not test the switch itself.
Hope this helps yah
Old Mar 26, 2009 | 05:22 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
is there a way to tell if the pulse board, motor, or switch are bad? i need to narrow it down versus spending 300 bucks on new parts
Old Mar 26, 2009 | 11:04 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
hmm noone knows??
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
