TEMP GAUGE WIRES
Old Mar 25, 2009 | 04:21 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
TEMP GAUGE WIRES
What color are the wires coming from the sending unit in the head.When I bought the car it had a cheepo sunpro temp gauge(mechanical)mounted below the dash.I replaced it with a automeeter and moved it to the a pillar.I would like to find out which wires they are.I have a known working temp gauge out of another cluster I`d like to use.Ijust need to know which wires to connect it to.I found a weather pack with 2 wires.A brown and a blue with white stripe cut after the weather pack.Also found a 4 wire connecter also with nothing plugged into it.I`ve searched and looked in the haynes/chilton and cant seem to find it in the wiring diagrams.
Old Mar 26, 2009 | 10:36 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: TEMP GAUGE WIRES
It should be dark green IIRC
Old Mar 26, 2009 | 09:45 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Any idea if its the same color inside the car to the cluster?
Old Mar 26, 2009 | 10:38 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
dark green from sending unit (drivers side head) to cluster harness inside of the car.
Old Mar 26, 2009 | 10:39 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Thanks,I`ll keep looking.
rocn7roc
Sep 21, 2021 02:16 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
