RFID/Pushbutton Starter Build
Old Aug 2, 2010 | 12:56 PM
  #51
ĦMR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
Re: RFID/Pushbutton Starter Build
oops. here is the right link http://www.youtube.com/watch?v=Dje9DepsxMY
I have updated/fixed the previous post.
Old Feb 28, 2011 | 09:09 PM
  #52
Car: '92 RS
Engine: 305 TBI
I posted an update on the first post.
I have a question for y'all.
The key fob that goes in your pocket will be battery operated. When the battery is low, there will be an LED that will blink to let you know. Would it be a deal breaker if the key fob could still unlock the doors with no battery, but at a reduced range (compared to with a battery)? Or is the low battery warning good enough?
Old Feb 28, 2011 | 09:18 PM
  #53
Scootermunch's Avatar
Car: 1989 Trans am GTA
i was considering moving my ignition lock cylinder, and after a horrid VATS problem in my daily driver last week, i am opting not to mess with relocating it. however, i would like to possibly manipulate the wires all 'stealth like'.
i was thinking, engine only starts if cigarette lighter is plugged in while turning ignition...
how would i accomplish this?
doesnt have to be the cigarette lighter... (i smoke so i might need it haha)
perhaps tap into the fog light button even?
Old Feb 28, 2011 | 09:25 PM
  #54
Car: '92 RS
Engine: 305 TBI
Well, the easiest way would be to cut the VATS wire that comes from the lock cylinder and put a switch/relay between the two ends. From there, you just need to use your imagination on how to interface the switch/relay. The only problem with messing with the VATS is that if you have really, really long really, really skinny wires, it may not work because it will change the resistance that is being read. Also, if the VATS resistance is wrong (open circuit, or too much/too little resistance) yo won't be able to try to start the car again for awhile.
Old Feb 28, 2011 | 09:34 PM
  #55
that is pretty much what happened with the daily driver. i didnt touch it before it went out though! funny that it happened during my research on moving the cylinder.
i know i can go through the vats and do it, but i think within the next few weeks, i'll run the bypass through VATS on both cars.
was thinking there is a good grounding wire i could splice off of.
bbsr72
Sep 27, 2015 05:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
Magman
Sep 13, 2015 12:07 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
