Remove headlights from a 1987 Pontiac Trans AM GTA
Old Apr 12, 2009 | 07:51 AM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
How do you get the headlights out of this car. I know you take the screw things and turn them so the headlights will both be up. Then you remove both black covers that have the four torx screws on both sides. OK my problem is how do you get at the philips head screws at the bottom of the headlight it is a tight squeeze there and remove the metal bezel that goes around the headlight. Why did gm have to make it so diffucult to change the headlights on the car?
Old Apr 12, 2009 | 08:22 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: Remove headlights from a 1987 Pontiac Trans AM GTA
get your screws out then you have to lower the light back down a little bit, then manuvere the black trim out.
Old Apr 12, 2009 | 08:46 AM
Steveh4263's Avatar
Engine: 5.7 LTR
The black trim is not the problem. Getting at the two metal screws at the bottom of the headlight bezel is the problem.
Old Apr 12, 2009 | 09:05 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
I just did mine about a month or so ago and I only removed the top screws and laid it forward to get the light out .
Old Apr 12, 2009 | 09:11 AM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
you could leave them in and bend the trim ring down and pull the light bulb out. but be careful use gloves as the ring is sharp.yes those screws are a pain and also they may be stuck and hard to turn to get loose
The_Phoenix
Feb 4, 2016 07:10 AM
I'llrocya
Feb 2, 2016 11:43 PM
gta power
Aug 13, 2015 06:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
