Battery Drain question
Old Apr 14, 2009 | 06:35 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
alright just like the title says i have a battery drain. its really started to **** me off to have to disconnect the battery every time i stop for a few hours. i need some advice, i could...
A. wire up a test light and start pulling fuses until the light goes out then work from there.
or
B. just wire in a kill switch and be done with it.
the only problem i have with a kill switch is that i have shaved door handles. i have handles but no way to unlock the car from the outside. If i wired in a key less entry system would it still work if the kill switch was still engaged?
any help would be greatly appreciated
Old Apr 14, 2009 | 07:33 PM
50bmgshooter's Avatar
Re: Battery Drain question
your best bet is to go at it with a test light and pulling fuses.
a kill switch will only be a band aide. also if you do a kill switch if you power the door locks from the batt side if the switch you will keep power to the locks at all time
Frozer!!!
Jan 19, 2024 04:55 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 9, 2015 05:27 PM
