Why do you need a vaccum advance distributor?
Old Apr 15, 2009 | 03:02 PM
Awesome-X's Avatar
Car: 87 Camaro
I was told they're good to have for daily driving but I don't understand why. I have someone willing to sell me one for my 305 for $25 and Im wondering what the pros of having one are.
Old Apr 15, 2009 | 03:20 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Why do you need a vaccum advance distributor?
Increased fuel economy, the vacuum diaphragm advances timing at part throttle cruise facilitating more complete, efficient, combustion. I think every daily-driver should have one. Keep in mind they are only applicable to non-cc cars, computer controlled cars have the same function programmed into the ECU.
-Z
Old Apr 15, 2009 | 08:59 PM
Awesome-X's Avatar
Car: 87 Camaro
Oh, well the dizzy I have on it works just fine but its been converted to carb so would it still work like it should?
Old Apr 15, 2009 | 09:10 PM
the zander's Avatar
If i understand correctly, you converted your fuel-injected (TPI or TBI) 305 to Carb? The distributor that originally came with the motor is therefore a computer-controlled HEI unit. Unless you retained the stock ECU alongside the Carb your distributor will most likely not function correctly. CC-Distributors dont have a mechanical advance system so as your RPM increase your timing will stay at the base value (bad).
-Z
Old Apr 15, 2009 | 11:02 PM
Awesome-X's Avatar
Car: 87 Camaro
Yeah, thats what I thought...so I need to go pick up this vacuum advance one then...thank you for explaining it to me.
Old Apr 16, 2009 | 02:42 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Yea you do need it for more performance and I had to do it to my old camaro but I just pulled one out for the junkyard from a old truck and it worked fine.
Old Apr 17, 2009 | 12:34 AM
Awesome-X's Avatar
Car: 87 Camaro
Cool, I think I'll go grab one I found on craigslist thats been recently rebuilt for $25. Hate to make the hour drive but its cheap and has vacuum advance. Stupid question I'm sure but what vacuum line should I hook it up to?
Old Apr 17, 2009 | 02:09 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
should have one on the carb if not about any manifold vacume will work as long as it doesn't have high demand stuff on it.
Old Apr 19, 2009 | 11:21 AM
the zander's Avatar
actually, for it to function properly the distributor needs to be connected to a ported vacuum source. a ported vacuum source will show no vacuum at idle and full manifold vacuum from part throttle - WOT. If you connect the distributor directly to manifold vac your base timing will appear way higher than normal.
-Z
MM2Robinson
Oct 1, 2017 09:16 AM
Zane Story
Oct 8, 2015 12:40 PM
Jorlain
Oct 8, 2015 01:57 AM
Jlanz55
Sep 6, 2015 03:05 PM
rjcme
Sep 5, 2015 01:23 PM
