knock sensor
Old Apr 18, 2009 | 12:31 PM
mudbucket72's Avatar
Car: 91 camaro
Engine: 3.1 v6
knock sensor
will this sensor not being pluged in keep the engin from starting
Old Apr 18, 2009 | 06:30 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: knock sensor
no, but it will run like ***** what year, engine, TBI , TPI, ... ect
Old Apr 18, 2009 | 06:31 PM
Car: 91 camaro
Engine: 3.1 v6
Re: knock sensor
91 3.1 v6 i think its mpfi
Old Apr 18, 2009 | 06:41 PM
Transmission: stock
Re: knock sensor
do you get a security light on the dash?
Old Apr 18, 2009 | 06:51 PM
Car: 91 camaro
Engine: 3.1 v6
Re: knock sensor
yes but it goes out after about 2 seconds i have pictures of alot of the wireing on another post
Old Apr 18, 2009 | 11:09 PM
Transmission: stock
Re: knock sensor
hook a test light up to an injector plug, try to start the car watch the light if it flashes the ign modual and the injector circuit are working, check fuel pressure at the engine, could be fuel pump or plugged filter whats the miles on the car??? over 100K most likely the pump
Old Apr 19, 2009 | 01:45 AM
Car: 91 camaro
Engine: 3.1 v6
Re: knock sensor
it has a new pump and it has 92,000 miles on it
Old Apr 19, 2009 | 01:51 AM
Transmission: stock
Re: knock sensor
ok check the injectors to see if they are getting power, should pulse
Old Apr 19, 2009 | 10:18 AM
Car: 91 camaro
Engine: 3.1 v6
Re: knock sensor
how would i go about doin that .. and i toggled the fuel pump and it works but i much rather have it work the right way i have a whole nother thread that may help with the explanation on the problem a lil more
Old Apr 19, 2009 | 10:20 AM
Car: 91 camaro
Engine: 3.1 v6
Re: knock sensor
its the very weird electrial problem thread
Old Apr 19, 2009 | 04:05 PM
Transmission: stock
Re: knock sensor
as stated before GET A TEST LIGHT!!!!
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
