Crank but no start.
Old Apr 19, 2009 | 08:27 PM
snakeeyes's Avatar
Car: 1987
Engine: 5.7L TPI
Transmission: 700r4 with shift kit
Axle/Gears: 7.5" G80
Crank but no start.
Well I have searched high and low in the threads for a similar issue...Here goes....
I have a 1985 Trans Am with a 305 4bbl H code and a manual tranny......
Car hadn't started for over a year...I put a new battery and starter in it and got it started.....worked for a few days but never idled properly...then all of a sudden it wouldn't start....cranked but no start....I pulled the plugs and found them bad so I put new plugs in it and it started great.....would start for about a week with just the slightest turn of the key....idled perfect.....then all of a sudden it won't start again......turns over but no spark....i put new wires, cap, rotor and coil and still got no start.....when i put the rotor on i noticed the mechanical advance was very rusty .....is this usual?
I have checked the grounds and wires after the starter.....but no start just got lots of crank and fuel.....I am without any more ideas....Does this sound like something anyone else has dealt with? Please help!
Old Apr 20, 2009 | 04:58 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Disconnect the 4 terminal connector at the distributor.
If you now have spark replace the pick-up coil in the distributor.
If you still have no spark let us know.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Apr 20, 2009 | 07:34 PM
snakeeyes's Avatar
Car: 1987
Engine: 5.7L TPI
Re: Crank but no start.
Thank-you I will give that a try....Cheers
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Jlanz55
Sep 29, 2015 08:55 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
