'87 GTA Digital Dash Non-Op
Old Apr 20, 2009 | 11:19 AM
1quik4's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 3.73's
I just picked up a beautiful '87 GTA.. Everything is great except the dash does not work.. It's a digital dash. The previous owner had bought another complete digi-dash from Ebay and tried it. It still does not work..
Any ideas of what the problem can be?
Old Apr 20, 2009 | 11:29 AM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: '87 GTA Digital Dash Non-Op
To start, check all fuses. Hopefully this is the problem and you don't have a break in the wiring somewhere.
Old Apr 20, 2009 | 12:53 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
yes, check the fuses. also, is it the whole thing that doesn't work or just a couple parts? my car is pretty much all original, the cluster and dash wiring was never cut save for the radio plugs. and with that said, if the courtesy fuse blows, for some reason the speedo goes over to KM and the odometer screen desn't work, heck the speedo reads all over the place too. i replace that fuse and it's good to go.
whatever you do, don't go analog. keep the digital, it's an interesting piece of trans am history and i think it looks so cool. but many on here will quickly tell you to dump it, f*ck that, it's a lot more work than just keeping it and fixing it.
Old Apr 20, 2009 | 11:32 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I've never seen a GTA digital dash up close,but on an
'89 chevy beretta digital dash the cluster is LCD and
there are 4 light bulbs behind the LCD panel - if these
are out (special halogen bulbs) the panel cannot be read.(the beretta cluster was made by VDO,on an'85
pontiac 6000 the cluster was made by nippondenso,
that one was a VFD cluster)
Old Apr 22, 2009 | 11:21 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
im having a similar problem. my odometer is just flashing 999999. could that be part of a blown fuse? or is it not plugged in to something correctly?
Old Apr 28, 2009 | 11:41 AM
you could check the fuses, remember to check the courtesy fuse, when mine blows the odometer doesn't work. chances are though, the circuitry went bad. you may be able to find a parts cluster and just swap that board out, i dunno.
Old Apr 28, 2009 | 03:46 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
hi I hope you figure out the problem and everything works out
MantyZ28
Nov 8, 2015 06:54 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
