Can the Resistor in the "VATS key" go bad? ---
Old Apr 23, 2009 | 01:31 AM
alwayscode390's Avatar
My car wont start once in awhile and I thought it was heat soak on the starter ... until I tried starting it today and it wouldnt start after sitting for 3 days, lol.
The security light does NOT come on, but all the lights work ... and no sound when I turn the key.
I only have one worn down key , and wasnt sure if the resistor could possibly go bad, and I need a new key ... or its probably the wires that I heard usually break/get loose in the ignition.
If its that, then its time to go to radio shack to get my resistance read, and get a resistor to do the bypass mod!!!
Thanks ---
Old Apr 23, 2009 | 09:00 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Can the Resistor in the "VATS key" go bad? ---
It's usually the contacts in the ignition cylinder that wear out, before the actual resistor pellet in the key.
If the bypass resistor works, it's definitely a problem between the key and ignition cylinder. The new cylinder isn't as expensive as new keys, though so be forewarned.
Lou
Old Apr 23, 2009 | 05:20 PM
Thanks Lou ---
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
bbsr72
Sep 27, 2015 05:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
studebaker60
Sep 7, 2015 12:36 PM
