HELP HELP HELP escalating electrical problem
Old Apr 26, 2009 | 09:36 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
first my tonneau release went out, soon after power locks, then all interior lights (exept gauges), and now a major concern for me; the cooling fan is out. although i replaced the fan motor and relay it still does not run; checked the fuses and they are in good condition.
(FYI) while raining some water manages to get in and my phone charger caught some of that water then shorted out
Old Apr 27, 2009 | 01:22 AM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: HELP HELP HELP escalating electrical problem
if you have a multimeter check all of the fuses for power with key on (you may have to pull a fuse at a time and check both connections One should be hot). If there is some with out, check the fusable links at the starter, if they are good check your IGN switch under the dash, but that wont explaine the dome lights, one step at a time ok
Old Apr 27, 2009 | 09:20 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Try this troubleshooting article.
http://www.austinthirdgen.org/index.php?pid=36
It will help you identify the cause of your malfunctioning fan. Refrain from buying any more new parts until you know WHICH ONE is bad.
Hope this helps.
Lou
Old Apr 27, 2009 | 11:06 AM
Transmission: stock
cool Lou I did not realize we had troubleshooting guides
Old Apr 27, 2009 | 12:10 PM
BigBadLou's Avatar
Engine: TPI
Yup, I wrote a few after I saw how many people have problems with their fuel pumps, cooling fans, door locks, starters etc.
Feel free to take a look: http://www.austinthirdgen.org/index.php?pid=2
Lou
Old May 1, 2009 | 12:57 PM
AJ87CAMARO's Avatar
Car: 1987 Camaro
Engine: 5.7 TPI
Check your battery cable might be the problem why the fans do not work. Find the wire that plugs into the wire harness for power to the fan or fans. Mine was bad so check out this site..www.innovativewiring.com
also check the cold start to make sure it works....check crk fuse to see if blown. hope this helps these where two problems that escalated all my eletrical problems.
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
