iroc dual fan issues
Old May 7, 2009 | 08:38 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
I just finished welding up my dual exhaust setup and i always dissconect the battery terminals when i weld on my car but when i took it for a drive yesterday and it never goes about 190 degF i have the prom programed to tunr the fan on at 170f but it never came on durning my drive. I have the secondary fan switched so i can turn it on any time, because it's not controled by the ecm. I tested all the relays and wires and the fans work. If i ground the green/white wire at the ecm the fan comes on, also my diagnostic computer says it's turned the fan on but still nothing. I switched the ecm the prom and i also dissconnected the a/c presure switch and it still wont come on. Does anyone have any suggestions? I don't mind running it off off the temp switch on the block but 230deg F is too high for my likeings and this problem is annoying me.
Old May 8, 2009 | 10:27 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: iroc dual fan issues
If you can turn the fan on by grounding the green/white wire on the ECM and the ECM says it's turning the fan on but the fan doesn't run, that logically leaves only one answer: bad ECM connector.
If you disconnect the harness from the ECM and ground pin E8, does the fan come on?
Lou
Old May 8, 2009 | 11:08 AM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
My diagram with the pinout only lists A 1-12 B1-12 C 1-16 AND B1-16. Theres no E section on the diagram. It's MAF car on an 87' iroc-z. Could you tell me what colour wire E8 is? Also when i ground the diagnotic poort on AB terminal neither fan comes on.
Old May 8, 2009 | 12:14 PM
BigBadLou's Avatar
Engine: TPI
The E8 is the green/white wire, the ECM pin that controls the primary fan relay, according to GM. Not sure if they're wrong.
Diagram here: http://www.austinthirdgen.org/mkport...ine_wiring.gif
What diagram are you going by? I'm curious how much they mis/match.
Lou
Old May 8, 2009 | 12:22 PM
BigBadLou's Avatar
Engine: TPI
After looking at the diagram closely, it might be wrong (well, go figure ). Which pin did you find the green/white wire on?
I looked at ChevyThunder.com and it seems that the Coolant Fan Relay Control is on C1.
Btw, you mentioned 4 sections in your diagram: A, B, C and B. I believe the last one should be labeled D.
Lou
Old May 8, 2009 | 12:37 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Ya sorry the last 1 is D, and i believe the green/ white wire is c1. also i just went for a nice drive and i left the ac pressure switch unhooked and the fan kicked on for a few momewnts but then it stopped all together. i'm thinking bad ecm ground or bad ecm connectors
Frozer!!!
Jan 19, 2024 04:55 PM
onefreakz
May 14, 2018 12:15 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
