88 TPI wiring harness question
Old May 12, 2009 | 01:36 AM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Hi,
I'm grafting an 88 engine wiring harness into a 92 V6 firebird. I was about re-pin the engine harness side of the C100 connector so that pin F8 of the body harness side has a ground connection (F8 is an airbag system ground).
Trouble is, there's already a pin in socket F8 of the engine side of the C100 connector. The diagram located below says pin F8 is not used, but there is a brown wire connected to the engine side of the connector.
Anyone know what this wire is for or where it terminates in the engine harness? I suppose I could move it to some other socket that also has no connection on the body half of C100 and then wire up my airbag system ground, but I'm also quite curious what the wire is for even though pin F8 is not used in an 88 harness.
Thanks!
http://www.austinthirdgen.org/mkport..._1989_C100.gif
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
