Power window problem
Old May 15, 2009 | 05:38 PM
WSS6's Avatar
Car: 1991 Pontiac Trans am
Transmission: WC T5
Axle/Gears: 3.45
MY passanger side window when rolled down only goes up small small amounts at a time. It will go up a few inches then i have to wait like 5 minutes and try again and it will go up like another inch. It goes down fine.
Even trying to pull it up wont work.
Do you think it is the motor or could it be something else
If anyone has any ideas it would be greatly appreciated
Thanks,
Old May 16, 2009 | 08:08 AM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
Re: Power window problem
That would be a motor problem. The breaker inside the motor is "resetting". Replace the window motor and all should be good again!
Old May 16, 2009 | 08:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Motor or the window is binding and causing the thermal switch to shut down until it cools enough to allow a restart.
JamesC
Old Jul 21, 2009 | 09:05 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
jamesc, how would one fix that; i have the same problem
thanks in advance
Old Jul 22, 2009 | 06:58 AM
JamesC's Avatar
Try adjusting the window guides (there are two at the top of the door frame). You'll have to remove the door panel. Pics in the following link, post #6:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Jul 22, 2009 | 10:23 AM
1Aauto's Avatar
Former Sponsor
We sell new power window motors.Here's a link over to them if you would like to check them out.The Pontiac & Chevy ones are the same.For some reason the single ones are only in the Chevy section.I'll have to have this fixed.
Pontiac Window Motor Kit
Chevy Camaro Window Motor
Old Jul 22, 2009 | 10:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For the motor install, check this link - it really makes it easy, and after 2 years, I've had no issues doing it this way:
https://www.thirdgen.org/forums/body...tall-easy.html
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
