Problem with directionals
Old May 20, 2009 | 07:52 PM
GPSkinzhut's Avatar
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
have an issue with just the rear directionals. They don't work at all. They worked for a second earlier, nothing now. The fronts works. The parking lights all work, reverse lights all work.
I'm green when it comes to electronics so if anyone has any advice on where to start looking I'll take it. Would a flasher do this?
Thanks and sorry if this is a repeat. Used search but the problems seem different so I figure I'd ask.
Old May 20, 2009 | 10:06 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Problem with directionals
The flasher powers both, the front and the rear. So if the front turn signals work, the flasher is good.
Have you checked the bulbs? That would be the first course of action.
The next course would be to take a test light (99c on sale at many stores) and probe the dark green and yellow wires on the tail turn signal sockets to see if the wires carry the voltage to the lightbulbs.
The third course would be to drop the knee panel under the dash (4 bolts) and test the dark green and yellow wires there to rule out the multifunction switch.
Let us know what you find.
Lou
Old May 21, 2009 | 06:18 PM
GPSkinzhut's Avatar
Thanks for the reply
Bulbs were the first thing I checked and they're all good. No worries there.
I'll try and get out tonight and test the circuit before it gets dark.
Old May 21, 2009 | 07:29 PM
GPSkinzhut's Avatar
Ah. It's something in the column. Tilt the wheel and they'll take turns working and not working.
Old May 21, 2009 | 11:13 PM
BigBadLou's Avatar
Engine: TPI
It could be just a bad connection at the bottom of the column (where the big flat white connector is - http://www.austinthirdgen.org/mkport...-connector.jpg ) or it could be the connection at the multifunction switch. That would be harder to get at but not impossible.
You can search the threads here on how to remove the steering wheel and access the multifunction switch.
Lou
Old May 22, 2009 | 07:25 AM
GPSkinzhut's Avatar
Will do. Thanks for the info Lou.
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
