Help with my electrical interior
Old May 24, 2009 | 03:25 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
I finally replaced my neutral safety switch with a used one because my reverse light weren't staying on when I would back up. The used neutral switch that I got was from the junk yard but it worked. My reverse stayed on and everything was good. I noticed when I was done I turned on my headlights and when I turned it off it hesitated to go back down.
Then I removed my headliner and in process I was trying to put the dome back with the retainer clip. I think I accidentally touched the fuse connections with my pliers because I saw a small spark. Now, my headlights won't go down, my dome light won't turn on, my mirror switch won't work and I'm confused as to what I did. My power windows work which is weird because my power mirror do not.
Any ideas what might have happened. I checked the fuses already and none of them seem blown. I'm wondering if its the neutral safety switch but at the same time all the electrical power worked when I put it in the new/used switch.
tommy z-28
Oct 6, 2015 10:58 PM
MORREALE5
Sep 13, 2015 09:01 PM
adelane
Sep 9, 2015 08:51 PM
sylentnite
Sep 9, 2015 02:55 PM
scottmoyer
Sep 7, 2015 07:06 PM
