not too sure wher to post but need help with fog lights
Subscribe
May 27, 2009 | 04:01 AM
ok i have a 91 rs and in the fuse box i have a place for fog lights... but no fuse... i am wondering if i have all the wiring for the fog lights just not the lights ... well i am not lookin forward to tearing into my dash to find out if the wiring is their but one would think it would be cuz of the fuse box... idk let me kno what you think. i wanna kno cuz i have fog lights but had to remove them cuz of a issue and i want to use the stock wireing if i have it.
Reply 0
May 27, 2009 | 05:45 AM
Re: not too sure wher to post but need help with fog lights
What you said in the beginning is the problem, NO FUSE!
Reply 0
May 27, 2009 | 08:06 AM
have you checked your RPO codes ? not sure but i think there is a code that tells if it left factory with them . if so the wires could still be there . good luck .
Reply 0
May 27, 2009 | 08:35 AM
wires are there they didnt make many different harnesses
Reply 0
May 27, 2009 | 09:54 AM
Quote: wires are there they didnt make many different harnesses
The wires are there, just no fog lights, no switch & therefore.....No fuse.
Reply 0
May 27, 2009 | 03:24 PM
looks to me all u need to do is take a trip to the j yard using the factory harness will be easy like plug and play
Reply 0
May 30, 2009 | 05:54 AM
ok so i looked all over for the wires for fogs but i cant find any factory wires... is there a harness i can get from a junkyard? plug and play???
Reply 0
May 30, 2009 | 06:43 AM
Quote: is there a harness i can get from a junkyard? plug and play???
Sure. I stripped one from switch to the lights (a bit of a pain trying to remove it from all the other wiring. I'd start at the fogs and work backward through the firewall). BTW, there are two types of switches: one illuminated, which has four prongs; one not, which has three prongs. This latter on older cars.
JamesC
Reply 0
Subscribe
