Starter Solenoid on new motor
Old Jun 1, 2009 | 03:30 PM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
For some reason the starter solenoid keeps dying on my motor all it takes is to lift the car and take a screwdriver to the terminals and it will start again
Im not sure whats causing it to do this but id hate to take the car out and it die on me
Im not sure if its because I have higher compression or not but I dont think that would be a factor for the solenoid itself
Thanks In advance
Old Jun 2, 2009 | 09:09 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Starter Solenoid on new motor
Have you tried troubleshooting the starting circuit yet?
http://www.austinthirdgen.org/index.php?pid=38
Lou
Old Jun 2, 2009 | 12:16 PM
aweTastic's Avatar
Yes everything has been double and triple checked so I have no idea what it is. Its only happened twice so far but its kinda scary
Old Jun 2, 2009 | 12:35 PM
BigBadLou's Avatar
Engine: TPI
So you checked it out and you get power on the purple wire on the solenoid while turning the key to Start but the starter doesn't engage the bendix or start turning?
Do you hear any sounds? Clicking?
What does the voltage do at that point? Don't use the dash gauge, use a voltmeter.
Lou
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Accerrito22
Aug 23, 2015 07:22 PM
Cleotiz
Aug 22, 2015 01:54 PM
milk
Aug 10, 2015 06:26 PM
