Hatch Motor Relay Question
Old Jun 2, 2009 | 12:05 PM
BLOWN25TH's Avatar
Car: 25th Anninversary Z28
Engine: Pro Charged 355
Transmission: Built 700R4
I am having issues with theh hatch pull down motor. I can get the motor to pull the hatch down but when i open it up with the key the motor does not push the latch back up to the top. In order for me to get the motor back to the top i have to unplug the motor and use a test light to trip the relay several time and then plug the motor back in. Does anyone know if this is a relay problem? Note: One time the car stalled and the hatch released but the motor did not come up.
Old Jun 2, 2009 | 12:56 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BATTEN DOWN THE HATCH
Sounds like switches/brushes are dirty/worn.
Try cleaning or replacing the relay.
Of course make sure all connectors are clean and tight.
If that doesn’t improve it disassemble the pull down unit, clean and reassemble.
It will buy a few more years for the unit.
If want a faster pit-stop swap it with a rebuilt.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Jun 2, 2009 | 02:53 PM
BLOWN25TH's Avatar
Re: BATTEN DOWN THE HATCH
Thanks for the info. I wll try all that you have mentioned and see if it helps.
Caspar
Jun 19, 2016 11:19 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
