Help on tach install...
Old Jun 4, 2009 | 07:53 PM
backinblack05's Avatar
I need some help. I have a 1990 IROC-Z with the 5.7 350. The person that owned the car before me had installed a aftermarket tach and now I am wanting to do the same. I believe there is some wiring left over from when he had installed it and I have included a picture. Could anyone tell me what wire goes where or what I need to do to get it hooked up? Thanks!
Old Jun 4, 2009 | 08:27 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: Help on tach install...
well...without instructions i can't be 100% but i think the red and black are hot and ground, the green is the trigger off the dizzy and the white is for lights off the dimmer.
Old Jun 4, 2009 | 08:52 PM
Yes thats what the instructions say, but what about the wires that are already in the car the gray and black? Can I use those is one of them the one that attaches to the green?
Old Jun 4, 2009 | 09:04 PM
vette gator's Avatar
Car: 85 Z28
Grey and black are for lights controlled by the dimmer (dash lights, shift indicator light, etc.). I'm pretty sure that what's in your picture is a light that goes in the bottom of the dash, just below the center vents. It points down to illuminate the ashtray, climate controls, etc.
In the motor compartment, the trigger wire from the distributor is brown. It's probably the same in the dash, but I'm not sure.
Old Jun 5, 2009 | 02:30 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
I think you are right about the brown wire for the trigger under the dash.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
