Help installing Direct-Wire Kit for Radar Detector
Old Jun 8, 2009 | 01:28 PM
yusky03's Avatar
I got this direct wire kit from eBay and I need some help installing it.
http://cgi.ebay.com/ws/eBayISAPI.dll...%3DI%26otn%3D1
I got it with the T-Tap but I am sure I can rig a wire to work for a fuse tap if needed.
I have a 91 RS and I need to find somewhere to ground it. Everything I can see is plastic next to the fuse box. Also I need a fuse or wire that is "switched". One that is off when the ignition is switched off and has 12 volts when the ignition is switched on.
Old Jun 9, 2009 | 09:27 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
RADAR LOVE
Ground wires are prevalent inside the knee panel.
You should buy a volt-ohmmeter meter.
There are many SWITCHED fuses in your block.
The blower is one of them.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
fasteddi
Sep 2, 2015 10:29 AM
crazynights
Aug 21, 2015 06:53 AM
drathaar907
Aug 6, 2015 04:20 PM
