issue with gauges when turning lights on
Old Jun 16, 2009 | 12:10 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
ok this is on an 86 iroc-z..... my gauges work fine when the headlights are off, however the moment i turn the lights on, the right side of the inst. cluster goes dead... lights, tach, oil, and volts.... also the turn signal indicator turns on solid..... the issue corrects itself the second the lights are turned off..... could this be a bad headlight switch or something else......
Old Jun 17, 2009 | 10:11 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: issue with gauges when turning lights on
That seems like a standard ground issue.
Either a bad connection on the back of the cluster or a bad ground for the cluster.
Lou
Old Jun 19, 2009 | 05:14 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
neone else?
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
