On the search for the bad wire or ground
Old Jun 19, 2009 | 10:11 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
ok so a few days ago i posted on how my car almost caught fire. here's my original post
"so i'm driving and i notice the volt meter is 18.
now i knew i had a bad ground, but instead of usually draining the battery, it did much more.
anyways im driving and the volt meter was at 18, then it was pegged, so was the temp gauge. the tach dropped and the car was sputtering. i quickly pulled onto a side street as smoke emerged from the gauge cluster, right by the volt meter soon followed by the tach.
i pop the hood and the battery was smoking pretty bad.
i disconnected the cables and let it sit."
so today i finally started pulling some things apart and i noticed some stuff. right when i pulled out the gauge cluster, the burnt smell was undeniable.
i smelled it particulary here
[IMG]file:///Scarlet/Cluster.jpg[/IMG]
and here
[IMG]file://localhost/Scarlet/Connector.jpg[/IMG]
i smelled it on the other side of the gauge cluster but i dont think it was as much.
i unplugged the connector that goes on top of the alternator, then sniffed the alternator, it smelled burnt plus i looked inside and saw the other part of the connector was burnt.
so now i know either the alternator had a play in it, or it was just a casualty.
the alternator is about 2 years old btw.
i couldn't dig any further today, i may tomorrow.
any ideas so far?
someone mentioned the fusible links, i dont know what those are
could someone explain?
Old Jun 19, 2009 | 11:00 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: On the search for the bad wire or ground
pics are not showing. try reloading them or something.
Old Jun 19, 2009 | 11:05 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
As I in the other post, Maybe the voltage regulator. I havn't had a chance to check my alternator or anything else. Hope you have better luck with this post.
Heres a bump for you .
Old Jun 19, 2009 | 11:13 AM
Convoy25's Avatar
heres the two pics. i really could smell the burn on the gauge cluster where the picture is showing
Attached Thumbnails On the search for the bad wire or ground-cluster.jpg   On the search for the bad wire or ground-connector.jpg
Old Jun 19, 2009 | 11:21 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, same place but on the speedo side. Also right above the location of the cluster pic was like a box with prongs, which is the back of the speedo, smelled burnts also.
Looks like we have the same problem, but on the opposite sides of the cluster.
Old Jun 19, 2009 | 11:26 AM
Convoy25's Avatar
well on the other side of the cluster i smelled it too, but it wasnt as bad. and like i said i looked at the alternator and on the plug on the inside, it smelled burnt as well and had the obvious looks of being burnt.
i'm hoping i could find out more before i take apart the entire dash.
oh btw as i was looking around about left center of the dash, looking down from the top, i saw a few wires with butt connectors and i was wondering what they were.
Attached Thumbnails On the search for the bad wire or ground-wires2.jpg   On the search for the bad wire or ground-wires1.jpg
Old Jun 19, 2009 | 11:35 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks like maybe speaker wires.
Old Jun 22, 2009 | 08:21 AM
Convoy25's Avatar
i'm thinking it could have been the alternator that went bad and caused all of this.
now would i need a new wiring harness? the gauge cluster smelled burnt and same with the connectors.
Old Jun 22, 2009 | 09:04 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Have you had the alternator checked?
I wouldnt think the harness would have to be replaced, just the cluster. Unless you found burnt wires under the dash.
Im no electronics/wire guru, maybe someone else will post.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Jae992
Aug 27, 2015 09:07 AM
