question about the sensor above oil filter
Old Jun 22, 2009 | 05:07 PM
xj7jag's Avatar
hi i was hoping someone could tell me what the sensor just above my oil filter is. i cant seem to find a replacement anywhere i can find the oil pressure sending unit but mo luck on the pressure switch thanks any help would be apreciated.
Old Jun 22, 2009 | 05:12 PM
white rider's Avatar
Re: question about the sensor above oil filter
Thats your oil pressure switch.
Old Jun 22, 2009 | 05:18 PM
xj7jag's Avatar
so thats the oil pressure switch? And the unit under the distributor is the oil pressure sending unit that sends the signal to the gauge?
Old Jun 22, 2009 | 05:21 PM
You have the same setup that I have in my iroc. The top one by the distributor is for the guage and the lower one by th filter is for the dummy light.
Old Jun 22, 2009 | 05:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it's the one that sometimes makes your oil press. readings act stupid . good luck .
Old Jun 22, 2009 | 05:31 PM
LOL!! I never knew that till one day I broke it and had to replace it. All of the sudden the pressure was great!! I'm so stupid!!! Sorry got a flash back....
Old Jun 22, 2009 | 07:56 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
To clear this up: our cars unfortunatelly don't have many dummy lights (I wish - should have bought a Ford ) so this oil pressure switch serves as a backup circuit to feed the fuel pump.
Hope this helps.
Lou
Old Jun 22, 2009 | 08:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by BigBadLou
To clear this up: our cars unfortunately don't have many dummy lights (I wish - should have bought a Ford ) so this oil pressure switch serves as a backup circuit to feed the fuel pump
Lou
I'd also like to add that in '88 or '89, the oil pressure gauge sender and oil pressure switch were combined into a single unit above the oil filter.
'87 and older had divorced units as white rider described.
Old Jun 22, 2009 | 08:30 PM
Mine is an 88 and it has the seperate ones.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
