I have a problem!
Old Jun 25, 2009 | 09:28 AM
camarodude5's Avatar
Car: 1990 Camaro RS
Engine: TBI 305 V8
Axle/Gears: 10 Bolt 2.73
I have a problem!
I have a 1990 Camaro RS and have some electronic problems. When I turn on the headlights only one turns on, but when I turn on the brights that headlight that didnt come on comes on and a bright light doesnt come on. I just would like to know some ideas of what could be causing this. Thanks!
Old Jun 25, 2009 | 10:38 AM
3rdGenDrifter's Avatar
From: I'm from hawaii, but I've been going to school in Grand Forks, ND for four years now
Car: 1989 Camaro, 1991 Firebird
Engine: 305 in the chevy, 350 in the bird
Re: I have a problem!
Almost the same thing happened to me a while back! I would get the two outside dims on low beam setting and when i switched to brights the two inside bulbs would come on and one of the outsides would turn off. I didn't expect this to be the solution, but I had it in the shop anyway so i mentioned it and they tried replacing the headlight that was turning off when i switched beams and for some reason that worked.
Beware though... this it probably an isolated problem, but recently this started: When i switch to high beams ALL turn off. I'm just about positive that it is purely the headlight dimmer switch causing this by not clicking over all the way. Just heads up
Old Jun 25, 2009 | 11:04 AM
Car: 1990 Camaro RS
Engine: TBI 305 V8
ok thanks for the info!
Old Jun 25, 2009 | 01:01 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
After checking for 12V+ at all of the light plugs, Replace all of your headlight bulbs.
Old Jun 25, 2009 | 01:48 PM
50bmgshooter's Avatar
this could be a simple adjustment on your high beam switch
if you pull the directional lever towards you does your high beam switch click?
if not you may just have to move it down the column just a touch.
Old Jun 25, 2009 | 11:20 PM
I feel like that could be a definite possibility, cause it seems like it almost wants to click over but doesn't quite reach (and i don't exactly wanna snap the lever off of the column either). How do you adjust that?
Old Jun 26, 2009 | 09:39 AM
on the steering coloum there is 2 switches the upper one is the ignition switch and the lower one is the high beam switch
the switch is held in with 2 screws just loosen the screws and slide the switch down a little retighten the screws and check for high beams
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
