plug?
Old Jul 1, 2009 | 12:31 AM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
plug?
There is a Plug right above the rear end of my camaro that has nothing going into it, i believe it has somthing to do with gas gauge the wires on the other side of plug were cut off but are black green and purple. Anybody know wat this plug gos to? and could this be why my gas gauge dosnt work?
Old Jul 1, 2009 | 08:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: plug?
The plug, if it were coming from the gas tank, was for the gauge and fuel pump. Purple, being the sending wire for the fuel gauge. Green, hot for the pump. Black, ground for the pump/sending unit.
The other end is not a dangling plug end but, in the center of the wall behind the backrest of the rear seats. Regardless of the termination end being there or not, the fuel gauge sender & pump wires ran under the drivers side door sill trim to the center of the rear seats
Short answer, yes, it's why your gauge doesn't work.
Old Jul 1, 2009 | 09:10 PM
Re: plug?
Alright thanks a bunch, another thing that helped was looking how my firends camaro is wired so i have pretty good idea what to do about it now
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
