slow blinkers
Old Jul 4, 2009 | 09:42 AM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
slow blinkers
so ive tried a search on this but coudn't find anything..ive got a 89 trans am GTA...my problem is that the blinkers blink slow...very slow..I changed the blinker flasher..all bulbs are good..they all blink, its just very slow..any input would be helpfull..thanks
Old Jul 4, 2009 | 09:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: slow blinkers
Did you change the correct Flasher unit??? There are two under the dash, one for the turn signals & the other for the emgr. flashers. So take another look this the problem in almost all cases of slow flashers.
Old Jul 4, 2009 | 01:51 PM
scott6281's Avatar
Car: pontiac trans am gta
Engine: 350 5.7L tpi
Re: slow blinkers
iam having the same problem but only my left turn signal does it. my right works fine.wanted to know where that flasher is located, so i can change it and see if that works?
Old Sep 11, 2011 | 09:24 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Re: slow blinkers
I have the same problem with my '91 Z. Blinkers are pretty slow, and are a bit random, on both sides. All the bulbs flash bright, too. It's a bit annoying, but seems to be an easy fix for the most part!
Old Sep 16, 2011 | 07:59 PM
BadGumba's Avatar
Car: 86 Pontiac Trans Am
Engine: 305 V8 Auto 4bbl Quad Carb.
Transmission: 700-R4 Auto
Re: slow blinkers
My signals were really slow flashing also on my '86 trans am, I replaced the flasher unit and they flash like normal now, so that is definitely the first place I would suggest checking, @threeohfive: not sure about your setup, but my turn signal flasher and hazard flasher relays were located in the convenience center drivers side right side of column under the dash on left side of radio area, if you turn your turn signals on you should hear where the flasher is.
Old Sep 16, 2011 | 08:12 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: slow blinkers
See...I actually WANT a slower flasher. Mine flashes too fast.
What flasher do you have? I need to find a slower flasher. 2 actually, Turn & Hazard, but mainly the Turn one.
Old Sep 16, 2011 | 08:15 PM
Car: GTA
Re: slow blinkers
BadGumba...I see you are near Austin. North? South? East? West? I'm NW & would be happy to meet up & trade my too-fast-for-me flasher for your too-slow-for-you flasher.
Old Oct 7, 2011 | 12:37 AM
Iroc-Z Tone's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
Re: slow blinkers
mine both work but they seem to get tired of blinking after a few seconds! lol. when I put my blinkers on they blink at normal speed then start slowing down until the blinker just stops blinking & stays on. any idea what it could be?
Old Oct 7, 2011 | 05:58 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: slow blinkers
Flasher.
Old Oct 8, 2011 | 09:52 PM
unapez's Avatar
Re: slow blinkers
Also check to be sure you have the correct bulbs installed, and they are all working. Flasher units correlate with with the bulb wattage. For example, your flasher will cycle faster when one bulb goes out, because it is not pulling enough power.
If you have a power drain, extra bulbs in the circuit, or bulbs pulling more than the recommended wattage for the system, this will slow your flasher.
However, sometimes it can be a flasher unit. I always replace mine with the heavy duty electro-mechanical units when they go out... they last 5x longer.
Old Oct 12, 2011 | 09:47 PM
Engine: 350 5.7 TPI
Re: slow blinkers
it was only my flasher, very easy $6.99 fix! THANK YOU!
Old Jul 27, 2012 | 11:09 PM
Ireneu Freitas's Avatar
Car: 1988 Firebird Trans Am
Re: slow blinkers
Im having the same problem, but only when my lights are on. Otherwise they blink normally. any ideas how to fix this?
Old Jul 28, 2012 | 12:02 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: slow blinkers
Check the blinker fluid.
Old Jul 28, 2012 | 08:50 AM
Re: slow blinkers
Well my car just died while i was driving and doesn't turn over anymore. so Im assuming my blinked problem had to do with either the battery or alternator being bad
Old Aug 5, 2012 | 10:47 AM
kevinlcook95's Avatar
Car: 89 GTA 5.7 t-tops/07 GMC Sierra SLT
Engine: 350 5.7 liter/ 6.0 Vortec Max
Transmission: built 700r4,shift kit,cvtte servo
Axle/Gears: Stock B/W 7.5 323 gears
Re: slow blinkers
lmao @ watajob...Great advice. the blinker fluid was low. Now its filled to the brim!! lol
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
