need help identifying these electrical connections / parts in a '84 Trans Am
Old Jul 22, 2009 | 10:09 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
i have a '84 Trans Am that is torn down to just the shell and i'm now trying to put it back together. i have a few things behind the dash that i'm not sure what they are or what they do. hopefully someone here can help.
both of the following parts are hanging under the dash on the passenger side. one looks like a relay maybe?? not sure what the other connection goes to.
also i have two complete dash harnesses. there's this plate that the diagnostic port is connected to and on the back of it there's all these relay looking things. on one harness this plate has a large black relay? on it and the other one does not. anyone know what this thing is and what it does?? it's the black thing behind the green and white things (sorry i don't know what these are called).
any help would be greatly appreciated. thanks.
Old Jul 23, 2009 | 06:15 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need help identifying these electrical connections / parts in a '84 Trans Am
The first pic shows a Power Antenna Relay.....
The second pic appears to be the power to your Heater/AC controller..... ( should be run behind dash so it pokes out inside the center console. )
The black "relay" in the third pic looks like the audio chime. (the one that reminds you when you forget to turn your headlights off after shutting the car down.....)
Hope it helps !
Old Jul 23, 2009 | 07:26 AM
battmann's Avatar
awesome! thanks so much for the information.
Old Jul 25, 2009 | 06:08 AM
battmann's Avatar
anyone know where the power antenna relay should be mounted??
Old Jul 26, 2009 | 12:13 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
from the hole on the relay housing, pretty much anywere that pleases you. then mount screw the ground on a nice clean bare metal surface (ground).
Old Jul 26, 2009 | 12:14 AM
can anybody help me out with my wiring issue? check my thread called Just rebult engine. Loose wires.
BRoss99
Aug 10, 2025 05:08 PM
mizz0313
Aug 12, 2015 06:45 AM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
