SES light does not come on with key forward
Old Jul 28, 2009 | 03:56 PM
1986iroc-z's Avatar
Car: 1986 Iroc-Z
Engine: 305 bored .30 over
I have been trouble shooting this one for a bit and have run into dead ends. This may be connected to my other post of the E wire on the ALDL not being connected to anything. I disconnect the ECM and the SES light comes on, connect the ECM the light goes out. With the ECM connected I can pull a code 12 out of it but nothing else. Any thoughts. Thanks
Old Feb 4, 2011 | 10:55 AM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Re: SES light does not come on with key forward
Sorry to bring up an old thread but i am experiencing the exact same thing. I have a 87 trans am TPI. Anyone have an idea what it could be? It also comes on briefly when going over bumps but when checked only throws 12.
Should also note that if i disconnect the batter for about 20 seconds and hook it back up it works normally.
Old Feb 4, 2011 | 11:58 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ECM Mayhem
The ECM might be subject to glitching do to degradation of the capacitors.
Check the brown wire with a WHITE stripe coming out of the dash which travels to the ECM for insulation rub-thru.
Happy Racing!
Maybe I Should Have The Guys Put A Door In The Bottom For Any Roll-Overs In 2011
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
