if only 1 fun from a set of dual fans is connected
Old Jul 29, 2009 | 07:03 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Transmission: Manual
Axle/Gears: 3.70
my 85 came originally with a single fan. i picked up a set of duals but currently only have 1 plugged in. will this cause the fan to run from the time that the battery is plugged in?
Old Jul 30, 2009 | 09:04 PM
Pocket's Avatar
Car: 91 Trans Am
Re: if only 1 fun from a set of dual fans is connected
Assuming you're using the single fan wiring with a new connector added, the second fan will operate the same as the first. If one comes on and the other does not, the idle fan is dead
Old Jul 31, 2009 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd 'assume' that one of the two fans would function just as the OE did.
JamesC
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
