were do these go??
Old Jul 30, 2009 | 12:15 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
were do these go??
I've looked and looked but i need a little help now, thanks in advance guys.
#1- Located around the coil on the passenger side of the car.
#2- Located on the passenger side of the car near the battery tray, has a ground connected to it which connects beside the battery.
#3- Located on the opposite side of #1 but more between the valve cover and the firewall. EDIT: if i remember correctly the wide colors are pink with a black stripe/ and black.
Attached Thumbnails were do these go??-dscf1918.jpg   were do these go??-dscf1919.jpg   were do these go??-dscf1920.jpg
Old Jul 30, 2009 | 12:17 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Re: were do these go??
#4- Located by the power brake booster/master cylinder.
Old Jul 30, 2009 | 01:31 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
really want to hear this thing run so help me out guys.
Old Jul 30, 2009 | 09:48 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
#1 - If those wires are tan and black, that's likely the extension connector for the IAT sensor under the upper plenum.
#2 - If the purple/black wire goes to ground, it goes to ground, no arguing about that.
#3 - Pink/black is operated by the ignition switch, black is ground. You'll see what it goes to once the harness is all in place and there's a disconnected device. If the black wire is just a dirty grey wire, it's the EGR connector, but doublecheck the wire color first.
#4 - I myself have no clue, hopefully somebody will chime in.
Hope this helps.
Lou
Old Jul 30, 2009 | 01:27 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
thanks alot ill have to go out there and check it out.
Old Jul 30, 2009 | 01:42 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
im gonna go check the #4 pic i think off hand that it connects between 2 harnesses by the wiper area but i dont remember. like i said i will check and get back to you.
Old Jul 30, 2009 | 02:39 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
this we pulled the motor out of this car and put in a whole new harness and everything so its not EXACTLY were its suppose to be but its close, thanks again.
Old Jul 30, 2009 | 02:47 PM
z28 TPI's Avatar
i just checked it and it is a connector that goes between the main ecm harness and the harness that comes out of the firewall on the drivers side below the esc and the fuel pump relay. the colors coming off the firewall harness are the same colors as the connector. funny you should metion replacing the harness i just did that no to long ago, so i kind of know what mess you are in lol.
Old Jul 31, 2009 | 01:06 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
it was literally a nightmare but thankfully im down to these last couple plugs and hopefully it'll start rite up.
