Hobbs switch needs a capacitor?
Old Aug 7, 2009 | 10:21 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I have a Hobbs switch hooked up to my fuel system. The switch is normally open and closes when the fuel pressure meets/exceeds the set point.
That switch is hooked up to a relay which, when switched off (Hobbs open=low fuel pressure) turns ON a warning light.
The Hobbs switch begins cycling on and off very quickly, several PSI before the set point. I suspect it is reacting to pressure pulses in the fuel system as it does it worst just off idle and not at full throttle. This causes the relay to start buzzing like a beehive and the warning light will flash at inappropriate times.
I added a 20V 150 UF capacitor across the terminals of the Hobs switch. I was careful to check the polarity and hook it up in the right direction.
Initial testing shows that this completely fixed the problem.
It now exhibits a hysteresis of about 1 PSI.
I've never played with capacitors much and am wondering...
Is the proper way to use one?
Am I in any danger of blowing it up (the polarity is correct)?
Would a higher capacity capacitor (As I suspect) yield a larger hysteresis? Not that I need it, just curious.
Thanks,
Old Aug 7, 2009 | 11:19 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Hobbs switch needs a capacitor?
Quick answers:
Yes
No
Yes
Hope this helps.
Lou
Old Aug 7, 2009 | 11:21 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
Thanks!
So far it seems to have made a HUGE improvement. I'll test it more this weekend.
Without the capacitor, the Hobbs switch was useless. I'm surprised that a search didn't turn up anything else on the subject.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
