Weird ignition problem
Old Aug 10, 2009 | 06:01 PM
buymytransam's Avatar
Car: 2005 Audi A4 Avant
Engine: 1.8T
1991 Pontiac Formula
5.0 TBI swapped out for carbed 350
*New starter*
Main wire to starter is hot
No power to solenoid
Wires going into the cabin through the firewall are hot
The alternator is out for a one-wire conversion
The computer is gone
Almost the whole wiring harness for the computer has been removed
I suggested that the circuit is incomplete with the alternator removed. The guy that had been working on my car while I was away says the alt being removed shouldn't matter. What the heck do I know, right? Anyway, wiring isn't my thing and apparantly it isn't his either.
Could it be the VATS? If there is some stupid aftermarket alarm installed, could that be causing this problem?
I have a combat start switch kicking around somewhere that I said he can use to bypass the factory ignition switch. Will this work? Any advice or suggestions would be great. I'm sure other members may find it very helpful as well.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
Bryan F
Aug 27, 2015 07:28 AM
CORV3TT3
Aug 23, 2015 11:26 AM
