Ignition switch help
Old Aug 26, 2009 | 07:16 PM
jag327's Avatar
Car: 82 Camaro
Engine: 327/30 over 1965 block
Transmission: 4 speed M22 trany
Axle/Gears: 373
Hi guys man I need help, I went to start the car with the key got nothing, with the ignition turn on, No radio,No wipers,no turn singles, But when I stick the key in the ignition switch the buzzer will ring. When I turn key acc still no radio or power going to it. I have push botton start switch that turns the starter over that is working find. Is there a fuse some where man if so I can't find it. Or could it be a bad switch, The hazzerd lights switch work on the steering column. I never play with the wiring to a key switch before.
The car is a 82 camaro with a tilt steering wheel.
Old Aug 26, 2009 | 07:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Ignition switch help
Wiring for the IGN is on the top of the column under the dash. I wouldnt bother replacing it until you rule out that you're getting power to the inside
Im unsure for older cars, but newer ones get power to the dash harness by the C100 connector. It has 2-4 large red wires that get power from the battery but are ran thru fusible links. These are located on the starter or a power junction block near the battery. If a fusible link blows the IGN switch gets no power so all your electronics are dead
Old Aug 26, 2009 | 08:23 PM
jag327's Avatar
Car: 82 Camaro
Axle/Gears: 373
I got power in the steering column the buzzer sounds when I turn the key in the ignition switch and the hazard lights work when I pull on them. But nothing when I turn the key...
Old Aug 27, 2009 | 10:29 AM
1Aauto's Avatar
Former Sponsor
Man what did the electrical gremblins come out this week on everyone..lol
Jag, If you find out that the switch is bad I have them in stock for your car. Their pretty short money.Just give me a shout if you have any questions.
Camaro Ignition Switch
Old Aug 29, 2009 | 01:00 PM
jag327's Avatar
Car: 82 Camaro
Axle/Gears: 373
I can feel the the rod on top of the steering moving back forth going in the ignition switch.
Old Sep 1, 2009 | 01:22 PM
jag327's Avatar
Car: 82 Camaro
Axle/Gears: 373
I found the problem a fuse link wire man pull everything lose, the funny on my tester I'm still getting 12 volts through it. I open up the wiring only 3 silver wires are together and the rest burt up... I'm ok now...
Old May 20, 2010 | 10:37 PM
peanutediii's Avatar
Car: 1982 camaro berlinetta
Engine: 305 4brl
Transmission: Na
Axle/Gears: Na
i am having the same problem i did a tune up and the car turns over but does not start or turn over before that the car ran fine and now it doesent run no lights work at all all the plugs are on the right firing order need help
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
