With Headlights on The Driver side Turnsignal Stays lit
Old Aug 27, 2009 | 06:49 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
The title says it all. The turnsignals work perfect when i dont have my Headlights on. But as soon as i turn my headlights on my front drivers side turn signal stays on solid. Not blinking just on. The Rear drivers side blinks, and the pass. side blinks but the front drivers just stays lit. I looked at the wiring and it doesnt appear to have been cut in the past.
So what do you guys think could be causing this?
Old Aug 27, 2009 | 07:35 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: With Headlights on The Driver side Turnsignal Stays lit
Bad ground.
Old Aug 27, 2009 | 07:52 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Originally Posted by ACCLR8N
Bad ground.
Check the little ground wire that goes to the headlight. I had this problem once before.
Old Aug 27, 2009 | 09:33 PM
heff17's Avatar
Car: 89 Camaro
is this the wires that look like there coming off of the little side marker? where would the ground be located?
Old Aug 28, 2009 | 09:51 PM
heff17's Avatar
Car: 89 Camaro
Ok so i found the ground wires under the rad. support that go to the headlights on both sides. I cut the wires, put new ends on, and even sanded the area around them and re-hooked them. Checked with a ohm gauge to make sure i had a ground connection with .6ohm resistance. Still didnt fix my issue. Any more ideas?
Old Aug 29, 2009 | 03:40 AM
jagmanofsteel's Avatar
Car: 88 Trans Am GTA
Transmission: Borg Warner WCT-5
Axle/Gears: 3.45
change the bulb. Trust me. I bet your turn signal indicator light stays on too.
Old Aug 29, 2009 | 09:22 AM
ACCLR8N's Avatar
I've also had the ground lead in the bulb socket itself rust out. But that would be in the forward turn signal double bulb and it should be dim.
Old Aug 29, 2009 | 08:24 PM
heff17's Avatar
Car: 89 Camaro
the bulb is dimmer than the other side. how could i check what your talking about acclr8n?
Old Aug 29, 2009 | 08:48 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Sounds like you have a short to positive from the headlight circuit to the turn signal circuit just on the driver side. If you turn on the driver turn signal with the headlights off, the left or both headlights might flash, but be very dim. The headlight circuit and turn signal circuit are 2 different circuits. If you turn the headlights on and the turn signal lights up with it on the driver side, the circuit is shorted together. I bet the rear turn signal comes on too but be very dim. Might not be able to see any light either since the front turn bulb is using up all the volts. Probably have to start tracing wires to find the short on the driver turn signal in the light harness if you dont see anything obvious.
Old Aug 30, 2009 | 08:59 AM
ACCLR8N's Avatar
Ground a small wire. Touch the other end to the collar on the front bulb or pull the bulb out and replace it with the new ground tucked in next to it. Just be sure the new ground doesn't reach all the way down to the two positive tabs at the bottom of the socket.
If that is the problem, new bulb sockets can be ordered from Rock Auto. If your cheap like me grind/cut away the socket plastic at the ground lead and re-solder the wire. Seal with epoxy or liquid tape.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Jae992
Aug 27, 2015 09:07 AM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
