Turn Signal Lever Sets off Horn
Old Sep 8, 2009 | 04:22 PM
tylerf's Avatar
Just bought a 88 firebird gta for a project car, just got the car up and going but nothing worked " dash, lighting, windows, etc," . Found that the pervious owner pulled a fuse out "crsk 20a" which powers every thing. Now that everything works, when i just touch the turn signal lever the horn goes off.
I have taken off the steering wheel but didn't want to go much further,
any help would be much appreciated. thanks
Old Sep 9, 2009 | 12:36 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Turn Signal Lever Sets off Horn
Well before you start taking things apart we should isolate where the problem is. Even though it seems obvious that it would be by the turn signal lever and may very well be this also may not be the case. Does it matter which way you turn the turn signal? does it happen if you switch the high beams?
Old Sep 9, 2009 | 01:18 AM
tylerf's Avatar
it dosnt matter how u touch it, moving it one centimeter makes it goes off, if its in the middle dosnt nothing, also when i use the turn signals it dosnt indicate in on the dash nor does high beams,
the blinkers and the high beam do work
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
