electric fan blowing fuses
Old Sep 13, 2009 | 12:25 AM
jwdrouyor's Avatar
Car: 1985 Chevrolet Camaro Z28
Engine: 8 Cylinders 5.0L FI
Transmission: Automatic
1985 camaro z28 305 TPI
a couple days ago i noticed my fan wasn't turning on. i know its supposed to run hot and the fan is to kick in around 230 degrees. so i decided to just put it on a switch in the cockpit.
i already check the fan and its free moving and does turn when i put power to it
here's my problem. I'm using a fuse and every time i connect it to power the fuse blows
now i have a stock fan. i am using 30a fuse, and 12 gauge wire
my set up is positive battery terminal to fuse and then to switch.
ground from switch and fan are connected to negative terminal.
and aux from switch to the positive lead on the fan
this is my first time trying to do anything electrical which is why i want it separated from all my other electrical in my car
am i doing anything wrong. how do i keep it from blowing my fuses, is the fan pulling more than it should. should i just skip the fuse all together or would that cause an issue
your help would be greatly appreciated, im so lost
Old Sep 13, 2009 | 01:14 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: electric fan blowing fuses
Perhaps try grounding the switch closer to the switch, instead of the neg. battery terminal.
Old Sep 13, 2009 | 01:33 AM
jwdrouyor's Avatar
i was having trouble trying to find a place to ground it. ill see if i can find a beeter one. how would the length blow the fuse? and then i also have another question, how much amps does a stock 1985 fan pull?
Old Sep 13, 2009 | 11:46 AM
jwdrouyor's Avatar
i was just looking at something and it said there could be a short in the fan motor. could that be the problem and why would that be the case??? what would cause the motor to have a short in it
Old Sep 13, 2009 | 03:57 PM
jwdrouyor's Avatar
alright i decided to go buy a new fan motor and it did the trick.
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
