bad fuse?
Old Sep 26, 2009 | 09:39 AM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
bad fuse?
hey guys been reading through the search and didn't find the answer i was looking for, is it possible that the fuel pump fuse (near the battery the 20 amp) to not be blown yet still be causing a problem?
Old Sep 28, 2009 | 04:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: bad fuse?
not likely - but that wiring system may have fault. The wire runs from a fusible link, through that fuse, then to the oil pressure sending unit, then to the fuel pump. there may be an issue with your oil pressure sending unit, located above the oil filter.
Old Sep 28, 2009 | 05:10 PM
Engine: 350(5.7L)
Re: bad fuse?
do i have to drain the oil to change that out?
Old Sep 28, 2009 | 05:52 PM
Car: 1992 RS
Engine: Carbed 350
Re: bad fuse?
no - no oil there unless motor is running.
Old Sep 28, 2009 | 06:24 PM
Engine: 350(5.7L)
Re: bad fuse?
much appreciated
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
