servce engine light dont come on????
Old Sep 30, 2009 | 08:26 PM
djtonysrs5.0's Avatar
hello all im new to this but i was wondering if anyone can help me get passed a smog. o.k all dash lights g on when i turn key but the only one that dont light up is the service engine light. so the smog guy wont pass me cause that light wont come on and off with the brake light. i took instrument panal off and change bolb but no dice. then i checked the wire to that light and i get no power. anyone know away to get this on or get around it. the car is in perfect condition ad runs great i dont wanna change a computer cause of 1 light..... help im going crazy!!! thanks
Old Oct 1, 2009 | 08:39 AM
1992_355's Avatar
Car: 1992 CAMARO RS
Engine: 355
Transmission: WORLD CLASS T5
Axle/Gears: 308
Re: servce engine light dont come on????
WELL TRY GETTING A STICKER SOMEWAER ELSE, I LIVE OUT IN THE COUNTRY & HAVE NO PROBLEM GETING INSPECTION. BUT ANY WAY I THINK ON SOME OF THESE CARS THE OIL SENDING UNIT WIRES RUN WITH THE CHECK ENGINE LIGHT.DOSE YOUR OIL PRESSURE GADGE WORK. CHECK THE WIRES FROM THE SENDING UNIT,BUT LIKE I SAID NOT ALL OF THEM WORK THE SAME.
CHECK UNDER THE PASSANGER SIDE OF DASH & SEE IF ANY WIRES TO THE ECM HAVE BEEN CUT OR BROKE.
Old Oct 3, 2009 | 05:10 AM
rock861261's Avatar
some bodys messing with you you have a cut wire from your ecm to your light probably have a check engine light on when they tried to sell it
Old Oct 3, 2009 | 08:48 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
I bet he is correct.
I don't have my OBD1 cable yet, used to just reading the codes off these with the paperclip method and flashing ses light, but if it's like i expect with my scanner reading enabled, i bet to confirm the cut wire theory, you'll find some codes set also.
i dont know if they check obd1 cars in cali, but for obdII's they do, and if you have a code it wont pass also. so once you get the light working, if there are codes set you might want to fix them before you go back to be told fail again if that's the case where u are.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
