Bright/Dim Light Question
Old Oct 4, 2009 | 10:26 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
When I turn bright lights on with turn signal switch dim lights go out. Shouldn't all 4 be on when put in bright mode? And if so,what's the problem?
Old Oct 5, 2009 | 08:58 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Bright/Dim Light Question
If the innner hi-beams come on, you have power to the high beams and that's good.
It sounds like either a dirty connector on the outer lights or maybe the high beam filaments in both of them are bad.
I'd try at least wiggling the connectors on the outer lights and if that doesn't help, I'd assume a bad high-beam filament.
Lou
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
