how many disturbutor plugs??
i have a 86 camaro i just put a 350 in and i just hooked up every thing and no spark from the dist. but i am wodnering if i dont have all the plugs pluged into it i have 2 plugs plugged in, my car was a 305 carburated and the 350 is the same not sure if i am missing a 3rd plug or not
( i have 1 pluged into the top of the cap and one into the wirring harness but the cap looks like it has a spot for a second plug up top)
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: how many disturbutor plugs??
should be a pink wire to "batt"on HEI cap,white to"tach"
3 wire plug from distributor base plugs into cap near
where the white and pink plug in,4 wire plug connects
to ECM harness(will run with the ECM plug disconnected
-just won't have spark advance)
wigmobile
Feb 26, 2025 02:56 PM
89 formula TPI
Sep 7, 2015 11:06 AM
