Headlights make gauges go crazy
Old Nov 1, 2009 | 01:33 PM
goodnight144's Avatar
I have an 86 Camaro with a 2.8L V6 and a 5 speed manual transmission. The gauges work fine (except gas but I was told that I would have to replace fuel pump for it to work) during the day, but when I turn my headlights on and my gauge lights turn on my rpm gauge and oil pressure gauge go crazy and they also jump around a lot if I use my blinkers. Any ideas?
Old Nov 2, 2009 | 02:35 AM
crug75hid's Avatar
Re: Headlights make gauges go crazy
definitely a case of short circuit. i mean the gauge lights and headlight pass through same flooring - wiring. there may be come crossover which is torn out. make that check
Old Nov 2, 2009 | 08:41 AM
Ok thanks I will dig around in there a bit and see what I can find.
Old Nov 2, 2009 | 10:04 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IIRC there's a ground for the headlights if the front on the passenger side.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
