need to wire in leds.....
Old Nov 10, 2009 | 12:04 PM
Guest
Guest
Posts: n/a
ok, so I got this kit so I wouldn't have to spend $600+ because I wanted blue lit gauges. Its a "wire in" kit but it has a battery pack but the switch is not a stick type switch (you have to hold it for it to work...." the wireing to the switch is cheap. Plus I want it to be legit and not rigged looking...Its a 12 volt 6amp I think and I plan on adding another set and I was wondering wheir I could wire this stuff in and if I could wire the 2 sets to the same place wheir the would be spliced in if that makes since....I do plan on putting a toggle switch in.
-their allready mounted and look mad ****en sic!!!! Best $20 bucks spend in the A Z ***** asile!
-thanks guys!
Old Nov 11, 2009 | 12:11 PM
Guest
Guest
Posts: n/a
Re: need to wire in leds.....
anybody
Old Nov 11, 2009 | 12:21 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
the switch and the small wire, and the batt are all for display reasons so you can see how they work without hooking them up, just hook the red to a 12v source or switch and the black to a ground and they will work, trash can the battery and micro switch or save them for some use down the road
Old Nov 11, 2009 | 12:26 PM
Guest
Guest
Posts: n/a
lol, you sound just like the box they came in. Im asking like wheir can I wire them in that will work and not screw anything up. Mabye sig lighter? Im still looking for a switch that I like and that will work with what im trying to do.
Old Nov 11, 2009 | 04:57 PM
89RS_82Z's Avatar
LOL i was a little puzzeled at first on why you asked that
anyway i would hook it into the 12v feed for the illumination on the radio, so they will come one with your parking/head lights
if you need help to figure out what wire that is post back up, and i will look it up and tell ya
Old Nov 11, 2009 | 05:02 PM
Pierced_Zombie's Avatar
Car: 1984 camaro z28
Engine: 305 H.O.
Transmission: 700r4 automatic
lol i was thinking about doing somthing simillar but was wondering if you can just change the original bulbs w/ led bulbs(like wire the led bulbs in were the original ones were)
Old Nov 12, 2009 | 12:06 PM
Guest
Guest
Posts: n/a
yea, lmk. Also I dont have a radio any more.....but the wires are all their....I post of pic of the leds when I get a camer, the speedo side needs to be adjusted tough...
Old Nov 15, 2009 | 12:45 PM
Guest
Guest
Posts: n/a
Got the L E Ds wired in their super bright and got my fogs wired in too, ill post some new pics up.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
