Oil pressure pegged out, erratic gas gauge
Old Nov 10, 2009 | 12:20 PM
redtruck18's Avatar
Car: 1987 RS Camaro
Engine: 305 V8 (Carb)
Ok, so my oil pressure gauge decided that it wants to point straight up at all times (pegged out)... i know my oil pressure isnt over 60. what may be causing this? I also notice that my gas gauge likes to bounce, all the time. Being as the car is carb'd i kinda understand the gas gauge, but why would my oil pressure be pegged out? Im pretty sure this has to be electrical, but if not please tell me. Could it be that the oil pressure sending unit is bad? or maybe just a bad connection? I have yet to pull the cluster and check the power levels, but im fairly certain ill find no power, so im confused as to why the gauge is all the way up. Even with the battery disconnected, the gauge is pegged out. Thanks in advance for the help,
Joe
Old Nov 11, 2009 | 09:30 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Oil Foil
Due to the fact it’s pegged with no battery, it’s defective and needs to be replaced.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 11, 2009 | 09:42 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Re: Oil Foil
I sort of have the same problem as well, except mine isn't pegged out all the time. I can start the car and it instantly peg itself and stays that way until I turn the car off. Does this mean I have a faulty gauge also or is the sending unit a problem? How can I test either to determine what is wrong?
Old Nov 11, 2009 | 10:08 AM
NINÅ's Avatar
Transmission: 765R4
Page 4 Gage
da.slyboy The first thing you should check for is a broken/disconnected wire from the sensor to the gage.
If none found disconnect the wire from the sensor and connect a 47Ω resistor to the wire.
Connect the other end of the resistor to ground.
Don’t start the engine but with the key in the RUN position if the gage reads about half way the gage is good.
That would mean the problem is the sensor.
Happy Racing!
Old Nov 15, 2009 | 07:01 AM
redtruck18's Avatar
Car: 1987 RS Camaro
Re: Page 4 Gage
would you replace the oil pressure sensor? Im not totally sure as to what you mean when you say replace it.
Old Nov 17, 2009 | 09:40 AM
NINÅ's Avatar
Transmission: 765R4
Page 4 Gage
redtruck18
Replace the gage.
Happy Racing!
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
