tach wire 89 rs
tach wire 89 rs
was wondering whatt is the wire color for the tach wire color. I cant find it when i start the car up it moves but it dont move when i rev the car up but when it starts it moves hmm.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
TIK-TAK
White.
Happy Racing!
If People Drove Any Slower Theyd Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Happy Racing!
If People Drove Any Slower Theyd Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
Re: TIK-TAK
thanks, I GOT IT HOOKED UP YES! wat about them red wires and light brown i still got them in the same wire loom and they arent hooked up you have and idea?
White.
Happy Racing!
Happy Racing!
Transmission: 765R4
TIK-TAK
Is anything not working in the car?
Happy Racing!
Happy Racing!
Re: tach wire 89 rs
yea i got a the same problem on my 83, Car starts and my tak shows it idle at 850 ish, than i rev the motor and it stays stuck at 3. and while driving it moves where it wants. could it be the wire for the tak running to the distributer? or could it be my gauge is done?
Transmission: 765R4
The Tach Is Back
There is circuitry in the dash near the tach.
Its contained on a small plug-in PCB or integrated in the main board.
On or near the PCB youll see a capacitor, replace it.
Also on the PCB youll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
Happy Racing!
Re: The Tach Is Back
Happy Racing!
Happy Racing!
good stuff, tach and oil pressure gauge are on my restoration list of things to make work
eightsixseven
Dec 16, 2024 01:50 PM
