VSS Buffer ID Help
Old Nov 17, 2009 | 09:06 PM
bj2times's Avatar
Car: 84 Corvette/84 Camero
Engine: 350 sbc
VSS Buffer ID Help
I am installing a 91 Camero dash cluster in my vette - I needed a "yellow box" vss buffer. I went to a boneyard and pulled what I thought was one from a stripped 1500 pickup. It has a delco PN 16185453 - also delco "QDU 16185645" The box is white but identical to the pics of the yellow units I've seen on this forum.
I pulled a large piece of the cable harness and there are 9 wires going into the larger connector on the box. There are no wires going to the 4 pin connector that is used for power on the yellow box.
Google can't find anything with these delco numbers - anybody know what this is? Is it just another version of the yellow buffer?. All I need is the frequency divider 4000ppm to 2000ppm.
Any help would be appreciated.
Old Nov 18, 2009 | 03:16 PM
bj2times's Avatar
Engine: 350 sbc
Re: VSS Buffer ID Help
Well, I found the answer to my question. For those that may fall into this trap - the 90 - 95 chevy trucks do not use a 4000ppm vss. They use a pinion mechanism that generates 82000ppm and a buffer that processes that. It looks like,smells like but is not a 4 0ut vss buffer. I am now the proud owner of one of these and I still need the 4 out.
Hopes this keeps someone elss from making this mistake - I just did not do my homework.
Old Nov 20, 2009 | 07:56 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'm pretty sure that the one from my S10 Blazer is the same as you describe..... plastic box in the same form but wrong color ! The truck is a 91 S10 Blazer Blazer 'Sport' with a factory digital speedometer.
I no longer feel the need to plug my white box into a thirdgen just to see what would happen ! Thanx for saving me from wasting that time & effort !
Old Nov 21, 2009 | 07:24 PM
bj2times's Avatar
Engine: 350 sbc
You are right John - the S10 is included in the units that run this DRAC or QDU module.
Bill
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
