fire wall plug
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: fire wall plug
Here's a link to Many of the ThirdGen C100 Connector diagrams......
http://www.berlinetta.info/C100.htm
This image is of the 87 Camaro C100 connector:
Re: fire wall plug
Sorry - I can't help Ya' with that one,........ You gotta' find someone with the factory service manual for that truck !
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: fire wall plug
By the way, it helps greatly if you would post the year of your car and the engine it has. The wiring may vary a bit from year to year and engine to engine.
Pink/Black is a general +12V circuit which is HOT when the ignition key is in the RUN, START, or BULB TEST switch position. On my 82 it is powered from both the Gauges Fuse and the ECM fuse. So we will need a bit more info to figure out where it may go to, once is passes through the firewall.
