help finding out speedo signal
Old Nov 24, 2009 | 09:07 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i had a 86-90 ish "large hole" electic sensor from a firebird/caprice etc... worked perfect wired directly to my 97 lt1 instrument cluster.
i have switched transmissions and am forced to go to a mechanical drive.
found several adapters to convert back to an electric signal.
my question is, what signal does the cluster need, or what was the rating on my old speedo sensor?
all the adapters i find are 8 or 16 "pulse per rev"
i remember from my dash swap searching that the speedo was 4000ppm. im just confused.
Old Nov 25, 2009 | 09:32 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Need 4 Speed-O-Meter
Your original sensor was geared to output 4,000 PPMi.
That’s what the BUFFER needs to see.
The BUFFER has up to 3 outputs depending on configuration.
One is 4,000 PPMi for the speedometer.
Another is 2,000 PPMi for the CRUISE.
The other is 2,000 PPMi for the ECM.
Because the adapters you found are 8 or 16 PPR, you need to gear them so they will render 4,000 PPMi.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 27, 2009 | 07:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help finding out speedo signal
http://tpiparts.net/inc/sdetail/7587
Old Nov 27, 2009 | 06:43 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thank you for all the info!!! TGO ROCKS!
glad i didnt order the 8 pulse one.
Old Nov 27, 2009 | 09:51 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
We aim to please
Caspar
Jun 19, 2016 11:19 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
